Will Invigorator Pro v4.5 work with After Effects CS6?
COW Forums : Zaxwerks
Gary Rice
on Mar 15, 2014 at 3:43:44 pm
The subject line says it all.
Gary
Edward Wu
Re: Will Invigorator Pro v4.5 work with After Effects CS6?
on Mar 17, 2014 at 9:44:23 pm
Hi Gary,
3D Invigorator PRO version 4.5.1 is a 32-bit plug-in and is not compatible with After Effects CS5 and above because they require 64-bit plug-ins. If you upgrade to our latest version, which is version 7, it will work without any problems with After Effects CS6 and After Effects CC.
By upgrading to version 7, you get all the new features of our lighting system. This lets you setup an entire stage filled with trusses, lighting fixtures, light beams and flares all with just a few clicks! In addition, use our Ray-traced renderer to generate ray-traced reflections, ray-traced shadows, ambient occlusion, refraction and more. Also, you can use our object drawing window to draw shapes and instantly have them extrude to 3D.
To upgrade, please visit our web store using the link below:
http://zaxwerks.com/price_list.shtml
If you have any questions, please let me know.
Best,
Edward
