export texture with .obj file
COW Forums : Zaxwerks
Theo van Laar
on Feb 1, 2014 at 11:48:38 pm
Hello,
I'm working with Proanimator 7.01 stand alone on a Windows 7 computer. I exported an obj file from a 3D text. I also would like to export the texture. The way I tried it is by FILE-COLLECT FILES. Then a SAVE AS window opened, but I'm not able to save anything.
What is the right procedure to save textures for obj files?
Thanks for your help.
Theo
Edward Wu
Re: export texture with .obj file
on Feb 4, 2014 at 12:01:06 am
Hi Theo,
ProAnimator does not export an .obj file with the texture map. It does export the UV mapping coordinates, but you will need to re-apply the texture in whatever 3D program you are working with.
The Collect Files command is used when moving a ProAnimator project file from one computer to another computer.
If you have any questions, please let me know.
Best,
Edward
Theo van Laar
on Feb 4, 2014 at 10:17:39 pm
Thanks, I will look into this!
Theo
