Lathe object "holes"
COW Forums : Zaxwerks
Liam Stirland
on Dec 5, 2013 at 4:10:25 pm
Anybody know a way to "drill" a hole in a lathe object? i have tried adding a cylinder with the matte colour, but it masks the whole object rather than just the hole i need.
Edward Wu
Re: Lathe object "holes"
on Dec 10, 2013 at 3:21:19 am
Hi Liam,
If you are wanting to punch a hole in the Lathe object (like cutting a shape and pasting in the lathe path in the drawing window), then there's currently no way of doing that. However, if you are trying to create a hole like a donut, what you can do is pull the path away from the Y-Axis in the drawing window. By pulling the path away from the axis, it will create a hole in the center of the lathe object. The lathe object revolves around the Y-Axis, so if the path is not touching the Y-Axis, it will create a hole in the center.
Hope this helps.
Best,
Edward
