Lathe object artifacting
COW Forums : Zaxwerks
Liam Stirland
on Oct 28, 2013 at 9:50:32 am
I am creating a custom lathe object by creating a circle, converting it to a lathe object then reducing the build angles to create a sort of 1/4 doughnut shape, All works fine apart from the ends of the custom lathe shape have huge 'spikes' extruding from them.
Any ideas?
Edward Wu
Re: Lathe object artifacting
on Oct 30, 2013 at 11:27:08 pm
Hi Liam,
Please check your email. I have sent you a revised version of the model. If you have any other problems with the models, please let me know and I'll do my best to assist you.
Best,
Edward
Jeremy Silverthorn
on Nov 22, 2013 at 6:57:29 pm
I'm having a similar issue myself... I have a simple outline created in illustrator and converted to a lathe object in ProAnimator... a pan. It looks great when the build angle is a complete 360, however when I change it to just make a pie shaped piece of my object (or remove a pie-shaped slice of the object), I get these crazy artifacts on the ends. I have tried a couple changes with the path in the illustrator file, however it has only given me a different artifact, not eliminated it. Any ideas??
