3D Invigorator PRO won't render out of After Effects CS6
COW Forums : Zaxwerks
Joshua Russell
on Oct 2, 2013 at 1:59:49 pm
I am having issues getting 3D Invigorator PRO to render out of After Effects CS6. It won't even give me a RAM preview in a 1080 comp. If I work in 720 it will give me a RAM preivew but it will only export the first few seconds of the COMP out of After Effects.
I have tried numerous Memory and Multiprocessing settings and had zero luck. Any thoughts?
Joshua Russell
Photographer/Videographer
Edward Wu
Re: 3D Invigorator PRO won't render out of After Effects CS6
on Oct 2, 2013 at 6:59:34 pm
Hi Joshua,
Which version of 3D Invigorator PRO are you currently using? I tried looking for you in our records, but could not find your license. If you are using version 5, be sure you are using version 5.1.0. If you are using version 6, be sure you are using version 6.1.1.
You can also try going into the Invigorator Preferences and turn off the "Use Multithreaded Rendering" setting and see if that helps.
Best,
Edward
Joshua Russell
on Oct 2, 2013 at 7:10:18 pm
I am using 5.0.3 Is that the issue? How do I get the updated software? The license is under Marcus Painton, for SEMO photo and video.
Joshua Russell
Edward Wu
on Oct 4, 2013 at 8:01:37 pm
Hi Joshua,
To download version 5.1.0, please use the download links below:
3D Invigorator Pro Mac Version Download Link
http://zaxwerks.com/downloads/Invig_AE_5.1.0p_mac.zip
3D Invigorator Pro Windows Version Download Link
http://zaxwerks.com/downloads/Invig_AE_5.1.0p_win.zip
Best,
Edward
