Invigorator Classic wire frame render
COW Forums : Zaxwerks
Malcolm Thorpe
on Aug 15, 2013 at 4:34:26 pm
I am trying to render animated 3d text in a wire frame style. However I can only use "standard color" in the Material set up. Older versions of Invigorator allowed me to select render styles but the latest/greatest version doesn't? What check box am I missing? Thanks in advance.
Edward Wu
Re: Invigorator Classic wire frame render
on Aug 15, 2013 at 5:21:01 pm
Hi Malcolm,
Were you using 3D Invigorator PRO previously? 3D Invigorator Classic does not support different rendering styles such as wireframe, absolute coloring, etc. If you were using 3D Invigorator PRO or ProAnimator in the past, this would explain why you were able to see these features, but not see them now.
Hope this clarifies the situation. If you have any questions, please let me know.
Best,
Edward
