Retaining original Illustrator file colors
COW Forums : Zaxwerks
Van Grafton
on Mar 27, 2013 at 4:25:55 pm
I am brand new to Invigorator and struggling through the initial learning curve. I have imported a logo created in Illustrator and want to keep the original colors. I checked the "Retain Colors" checkbox during import, but I still lose the original file colors. No doubt this is simple user error/ignorance on my part. Any advice would be appreciated.
Thanks in advance.
van
Edward Wu
Re: Retaining original Illustrator file colors
on Mar 28, 2013 at 6:19:54 pm
Hi Van,
Be sure you are using RGB colors and are not using gradient colors. If you are using a gradient color, you will have to either apply the gradient color as a texture map, which means first saving the color as a jpeg image and importing the image into Invigorator, or creating the gradient color in Invigorator instead.
Also, in Illustrator, be sure you are working with a fill color and remove the stroke. If you have a stroke on your object, this will cause the colors to not show up correctly.
If you have any questions, please let me know.
Best,
Edward
