Copy a layer but not take materials with it
COW Forums : Zaxwerks
Nico Jones
on Nov 20, 2012 at 6:10:51 pm
Hallo,
I've copied and pasted to create another instance of a layer in Invig. But when I add materials to either the new layer, or the original one, it applies it to both layers rather than just one. Any way round this?
Nico
http://www.hiddendoor.tv
Edward Wu
Re: Copy a layer but not take materials with it
on Nov 20, 2012 at 11:45:56 pm
Hi Nico,
If you are talking about duplicating an object in Invigorator PRO, then you will need to unlink the materials. To do this, select the duplicated object. Then, go to the "Object Style Swatches" panel. In the "Material Commands" menu, select "Unlink Object Style". Then you will be able to apply a different material to the duplicated object.
Best,
Edward
Nico Jones
on Nov 21, 2012 at 10:38:58 am
Ah nice one, thanks! I'd have expected that switch to be in the object control panel...as it's a crucial feature, and I never actually use object styles, so would never think to look for it there...
Edward Wu
on Nov 23, 2012 at 5:20:57 pm
Hi Nico,
Thanks for the suggestion. I will bring this up to our team for the next version of our release.
Best,
Edward
