Invig Pro 5.x work with AE CS6?
COW Forums : Zaxwerks
Jim Wilcox
on Oct 17, 2012 at 12:27:55 am
Checking to see if Invig Pro 5.09 works with AE CS6 or do you have to upgrade. It seems to draw frames in draft, but will just sit and spin when set to full quality...
Edward Wu
Re: Invig Pro 5.x work with AE CS6?
on Oct 17, 2012 at 5:08:40 pm
Hi Jim,
Version 5.1.0 works with After Effects CS6, but you will have to turn off Disk Caching for it to work properly. If you need the download link for version 5.1.0, please e-mail me at ed@zaxwerks.com and I will provide the download link for you.
With version 6.1.0, the plug-in is optimized for After Effects CS6 so it will perform much faster and you will not need to disable the Disk Caching feature in After Effects.
Best,
Edward
