Warping Text - which version?
COW Forums : Zaxwerks
Steve Clarendon
on Aug 27, 2012 at 12:26:50 am
I have 3D Invigorator PRO 4.5.1 for After Effects. Does anyone know which version came out which offers the ability to warp text with 3D Invig? I know version 6 does but do any earlier versions (such as 5) offer this option?
I should specify - I need to be able to apply curvature to text withing Invig...as if text were circling a sphere.
Edward Wu
Re: Warping Text - which version?
on Aug 28, 2012 at 12:17:20 am
Hi Steve,
Right, the Warping features were first introduced in version 5. So, if you are interested in applying curvature to the text, you can upgrade to version 6 and it will have the warping feature along with many other features such as the Ray Traced Renderer, Grid Shader and more. If you are working with After Effects CS4, we can send you the download links and the authorization code for version 5 once you upgrade. Then, when you upgrade to After Effects CS5 or CS6, we can also send you the download links and authorization code for version 6.
Best,
Edward
