Warps within Invigorator 6
COW Forums : Zaxwerks
Roger Burton
on Aug 11, 2012 at 3:52:48 pm
Hi - I know there's a Zax warp plugin but in Vers 6 Invig pro there are warp controls that can be applied to a set ... very nice but I have created a curved glass "wall" and the lighting hasn't been affected by the curvature ... ie it looks flat ... anyone know what I need to try and do to give it some 'life' ... many thanks
Roger
Roger Burton
Re: Warps within Invigorator 6
on Aug 11, 2012 at 3:59:28 pm
I should have added, I tried using comp lights but it just turned my nice white 'floor' black ...
Edward Wu
on Aug 14, 2012 at 4:06:32 pm
Hi Roger,
When you're using Comp Lights, keep in mind that you may need to add multiple lights to brighten up the scene. By default, Invigorator uses 3 lights so that is why it will be brighter than if you've just set up 1 parallel light in After Effects.
Best,
Edward
Edward Wu
on Aug 14, 2012 at 4:04:50 pm
Hi Roger,
The lighting does update if you warp your objects. If you're still having problems, please send the project file to me and I will take a look at your setup. Thanks.
Best,
Edward
