Change default bevel?
COW Forums : Zaxwerks
Michael Stephens
on Aug 10, 2012 at 2:26:56 pm
Is there a way to change the default bevel for 3D text and Illustrator objects in ProAnimator. I use the basic, sides flat bevel the most and it would be nice to not have to change it to this every time I create 3D text or import an Illustrator file.
Edward Wu
Re: Change default bevel?
on Aug 10, 2012 at 4:03:11 pm
Hi Michael,
At the moment, we do not have this feature. It's a good suggestion though, so I will bring this up to our development team as a feature that we can add for the next release.
For now, you can create all the objects that you need, then do a Select All command, change the bevel to the "Basic, Flat Sides" and it will change the bevel for all the objects at once. Hopefully this will speed up the process a little bit.
Best,
Edward
