3D Invigorator and shadows - AE lights vs Invigorator lights.
COW Forums : Zaxwerks
Colin Carver
on Jul 18, 2012 at 12:55:58 pm
I have a 3D model loaded into Invigorator, and I want it to cast shadows. Obviously the way to do it is create a shadow catcher plane in Invigorator. That works fine, and when I case a light onto the model, I see the shadows as I expect, but I've noticed something, at least when using After Effects lights: Although the model does cast shadows correctly onto the shadow catcher plane, I've noticed that the model doesn't cast shadows onto itself. It does do this when I use Invigorator lights, but not when I use AE lights. Am I doing something wrong or is this a limitation of using AE lights instead of Invigorator ones?
Colin Carver
Re: 3D Invigorator and shadows - AE lights vs Invigorator lights.
on Jul 18, 2012 at 1:01:54 pm
OK this is weird! I've just finished rendering a composition using AE lights and the model IS casting shadows on itself in the final render, but I can't see this happening in AE, even though I have full resolution and full quality turned on. The exact same composition I just rendered that shows the shadows correctly in the rendered footage, doesn't show them correctly inside After Effects. If I disable AE lights and enable Invigorator lights, I can see the correct shadows in AE. I'm confused! :)
Colin Carver
on Jul 18, 2012 at 1:13:28 pm
OK. It seems I had a corrupted comp. I just built up a new test comp from scratch and that seems to be working perfectly. Sorry about that!
Edward Wu
on Jul 18, 2012 at 7:24:03 pm
No problem at all. I'm glad to hear it's all working for you now!
Best,
Edward
