3D Invigorator BEHIND After Effects 3D layers?
COW Forums : Zaxwerks
Mike Berry
on May 28, 2012 at 3:08:47 pm
Is it possible to have a 3D Invigorator model appear behind selected AE 3D layers? For example, if I were to make a simple cube using AE layers, could I place an Invigorator model inside the cube so that (as in real life) it would be invisible until one of more of the AE layers was removed?
Edward Wu
Re: 3D Invigorator BEHIND After Effects 3D layers?
on Jun 1, 2012 at 4:23:30 pm
Hi Mike,
Sure, 3D Invigorator PRO works with the After Effects layer hierarchy. This means if you have an After Effects layer placed on top of the 3D Invigorator PRO layer, then it will cover up the Invigorator elements until the After Effects layer is removed or made invisible.
Best,
Edward
