zaxwerks proanimator presets
COW Forums : Zaxwerks
Aqeel Sami
on May 11, 2012 at 7:45:08 pm
I used to install zaxcwerks proanimator without problems but last time i formated my pc i noticed that there are no presets and when i tried to load them into script folder of after effects cs55 they didn't show when i load the filter. is there a solution for this problem.
Zax Dow
Re: zaxwerks proanimator presets
on May 11, 2012 at 10:45:29 pm
Open ProAnimator, then open the Preferences and click the Restore To Factory Presets button, then Exit and relaunch ProAnimator.
If this doesn't fix it take a look at this FAQ from the Zaxwerks Help Center: http://zaxwerks.com/helpcenter/faq7.shtml
It tells you how to reset the factory presets
Aqeel Sami
on May 12, 2012 at 10:56:30 am
when i installed the software to a folder in desktop i found that standalone proanimator doesn't installed although i checked it to be installed and presets folder is empty and some other folders....does that help to solve the problem.
Zax Dow
on May 15, 2012 at 7:55:45 pm
Are you trying to run the installer from inside of a ZIP file?
You must unzip the zip file before trying to run the installer.
