How large can I make a layer map (pixel dimensions) for ProAnimator?
COW Forums : Zaxwerks
James Huenergardt
on Apr 24, 2012 at 2:16:11 pm
I'm trying to create an animation using ProAnimator where I have a globe and the continent of Africa is filled with video tiles (using a trkmat).
I'm wanting to start with the camera pushed into a single tile and then pull out to reveal the continent of Africa on the globe.
I can get this to work, but I'm currently not happy with the results.
I'm wanting to have hundreds of clips filling Africa, but right now, the most I can get is about 67.
The issue is that when I push the camera in close enough to fill the frame with one video tile, the tile is soft.
I tried making a bigger layer map, but then ProAnimator doesn't seem to show anything.
Any ideas/suggestions? What's the max pixel dimension of a layer map for ProAnimator?
Jim
Reel Inspirations - http://www.reelinspirations.com
Commercials, Dramas, Image Pieces, Documentaries, Motion Graphics
Edward Wu
Re: How large can I make a layer map (pixel dimensions) for ProAnimator?
on Apr 25, 2012 at 12:29:05 am
Hi Jim,
As discussed on the phone, try rendering out the Pre-comp since you're using such as large Layer Map. Then use the video as a Layer Map and see if this works better for you.
If you're still having problems, please let me know. You can contact me directly at ed@zaxwerks.com and I'll be able to help you out.
Best,
Edward
