Reloading AI files within Object Controls not working correctly with version 5.0.9
COW Forums : Zaxwerks
Brett Witte
on Feb 22, 2012 at 6:33:41 pm
I just upgraded to 3D Invigorator Pro 5.0.9.
I am creating a Pittsburgh Pirates Logo in 3D. I saved all layers individually in AI. I import and set all layers that I require with no problems, but this logo has needed me to go back to AI and make some vector adjustments. When I reload the layer, the vector is imported wacky looking. As a test, I tried doing this to a Penguins logo I created in 3D a while back and I am getting the same issue. I've never had this reload issue with version 4.0. Any ideas why this is happening?
Brett
Brett Witte
Re: Reloading AI files within Object Controls not working correctly with version 5.0.9
on Feb 22, 2012 at 6:59:12 pm
Also, even if I don't actually make an edit in AI, but do a reload I still get this problem. I did a sample with "P". Comes in fine first time. If I reload, the P without even making edit within AI, it disappears and the hole within P becomes solid. Just FYI, using a MAC Version 10.6.4.
Matt Rhodes
on Feb 22, 2012 at 11:48:29 pm
Hi Brett.
There does seem to be a problem with reloading a layer.
I'm looking into it. Stay tuned.
Matt Rhodes
Zaxwerks, Inc.
Matt Rhodes
on Feb 23, 2012 at 12:42:18 am
Hi Brett.
Please email me with your contact information.
We'll send you an update with a fix to your "replace layer" problem.
Thanks.
Matt Rhodes
Zaxwerks, Inc.
Email: matt@zaxwerks.com
