Turning off sets in 3D Invigorator Pro
COW Forums : Zaxwerks
Colin Carver
on Feb 21, 2012 at 6:35:34 pm
Is it possible to turn sets on and off in Invigorator Pro?
I have a composition that calls for three different 3d models to turn off and on (only one model visible at any one time) and I can't work out how to do this other than perhaps putting in keyframes to change the position values of the models to move them off the visible screen when I want them to turn off!
Colin.
Edward Wu
Re: Turning off sets in 3D Invigorator Pro
on Feb 21, 2012 at 6:55:33 pm
Hi Colin,
We currently don't have controls to turn a Set on or off. However, you can have several layers that each have Invigorator PRO applied to it. This means, you would put each object in its own Invigorator Layer. Then you can use the transparency controls to hide the Invigorator layer.
Hope this helps.
Best,
Edward
Colin Carver
on Feb 21, 2012 at 6:57:47 pm
Thank you for the quick reply and information, Edward.
