Rough/Jagged shadows - 3D Invigorator Pro (PC/After Effects)
COW Forums : Zaxwerks
Martin Braben
on Jan 30, 2012 at 9:55:25 pm
I have a model imported into Invigorator Pro and when I try to add shadows to my lighting, the shadows appear jagged/rough/stepped. Adjusting the shadow smoothness slider doesn't really help, unless I push it to a point where the shadows are ridiculously soft.
Here's a cropped photo of my model with softness set to 4:
http://www.imgjoe.com/x/shadowson.jpg
Here's the same image without shows applied:
http://www.imgjoe.com/x/shadowsoff.jpg
The thing is, I loaded in this model to Invigorator about a week or two ago, and applied lighting/shadows to it, and as I recall, it looked perfectly fine. Something has obviously happened that I haven't noticed since, but I do not recall changing any setting in Invigorator at all! I've tried resetting Invigorator to its default settings, but this does not help.
Edward Wu
Re: Rough/Jagged shadows - 3D Invigorator Pro (PC/After Effects)
on Feb 1, 2012 at 12:46:39 am
Hi Martin,
Try adjusting the Shadow Map size by going into the Invigorator Preferences window. By default, this value is set to "500". The higher the value, the sharper the shadow will be. However, keep in mind that increasing the Shadow Map size will also slow down the rendering and preview time.
Best,
Edward
