texture map proanimator
COW Forums : Zaxwerks
Steve Hines
on Nov 25, 2011 at 6:15:57 pm
having trouble using texture map specifically sizing..when I bring in psd file the size doesn't match the 3d object..am I saving the psd incorrectly..using proanimator vers 4.3.1
or direct me to this subject here if already and I assume so, answered
thanks
Edward Wu
Re: texture map proanimator
on Nov 25, 2011 at 7:14:41 pm
Hi Steve,
Be sure to crop the Photoshop document so that there are no margins around your image. This means, you will need to crop the top, bottom, left and right to the edges of your image. If your texture map has margins, then the map will not match the Illustrator outlines.
Hope this helps.
Best,
Edward
