rounding the front face of text
COW Forums : Zaxwerks
David Miller
on Nov 14, 2011 at 10:08:36 pm
Does anyone know how to round the front face of the text or to chisel it to a point like the Harry Potter text in ProA 5?
thanks
David
Fernando Mol
Re: rounding the front face of text
on Nov 14, 2011 at 11:39:57 pm
Bevels use flat fronts. You can experiment with the Edge Offset and Bevel Scale using the bevel "Flare, Straight". But that will hardly work on irregular fonts, like the Harry Potter one.
It's a good question, I wonder if someone can come with a better tip.
Edward Wu
on Nov 15, 2011 at 8:19:18 pm
Hi David,
Right. You can either play with the Edge Offset, or manually edit the text outline in the Drawing Window so that the text is really thin. Then you can apply a Round Bevel like Fernando suggested, or create your own bevel in the Profile Editor.
If you have 3D Serpentine, you can try using text as the Serpentine Body, and then applying a round end cap.
Hope this helps.
Best,
Edward
