make object wiggle in Proanimator
COW Forums : Zaxwerks
Mark Driesen
on Nov 10, 2011 at 9:53:23 pm
Hi guys,
I would like to have an object wiggle after it spins on the x axis...
Is there a way to do this in PA?
Someone on this forum stated this can be achieved with layer cycling...? How?
Anyone?
Mark
Edward Wu
Re: make object wiggle in Proanimator
on Nov 15, 2011 at 5:46:21 pm
Hi Mark,
I'm not sure how you want the objects to wiggle, but one way to achieve this effect is to create many poses, and adjust the Global Scale for the objects. By changing the Scale value from big to small, and vice versa, you will start getting the wiggle effect.
With Layer Cycling, you would be changing the shape of the Illustrator object from layer to layer. Then when you load the Illustrator file as a Layer Cycling Object, it will play the animation using the layers from Illustrator.
Best,
Edward
Mark Driesen
on Nov 15, 2011 at 6:18:03 pm
Hi Edward,
what I mean is letting part of a text wiggle or 'swing' like it's hanging...
I'm not sure if this is clear, but this would mean the top of the text is not moving, and just the bottom is wiggling forward and backward and after a while comes to a stop.
I suppose this could eb solved by creating an other pivot point...?
Mark
Edward Wu
on Nov 15, 2011 at 8:22:33 pm
Hi Mark,
From your descriptions, you'll want to use the Warping feature in ProAnimator version 5. This allows you to bend your text. By setting Warp Poses/Transitions, you can bend part of the Text back and forth, and you should be able to get the effect you're looking for. To add a Warp Track, select your Object Track, go to the Track Commands, and select "Add Warp Track".
Hope this helps.
Best,
Edward
