3D layer warp
COW Forums : Zaxwerks
Jim Wilcox
3D layer warp
on Aug 17, 2011 at 4:10:05 pm
working on a project in that originated in AE CS3. Its now open in CS4 (9.0.3) running mac OS 10.6.6 and Layer warp 1.5.1. The backfacing color map is now either a random checkerboard pattern or just a full size of the assigned layer - not taking on the shape of the main front layer to which LP is applied. This all worked fine in CS3.
Is there a work around or is this a bug of some sort for CS4?
Edward Wu
Re: 3D layer warp
on Aug 17, 2011 at 10:31:35 pm
Hi Jim,
You may be running into an issue where the "Best Geometric Detail" is not set high enough. Try increasing the value to "600 x 600" or higher and see if this works out for you.
Best,
Edward
