Reflector
COW Forums : Zaxwerks
Jim Wilcox
Reflector
on May 18, 2011 at 1:58:31 pm
I am wondering if I a running up against size limits for reflector. I have a SD comp with about 20 cards set up in a 3D ring with camera and floor. Apply reflector to floor and I get the reflection working, but even using the update script the reflection does not update with the camera move and randomly crashes without any error message. Running AE CS4 w(9.0.3) with reflector 2.0.0.
Edward Wu
Re: Reflector
on May 18, 2011 at 7:10:49 pm
Hi Jim,
When using the Updater Script, be sure you are clicking on the "Update Comp" button. This will update all the frames in your animation.
If this is still not working for you, please send the project file to me so I can take a look at your setup.
Best,
Edward
Jim Wilcox
Re: Reflector
on May 18, 2011 at 8:05:39 pm
Edward,
I am using the update comp button. If I update frame that works as it should but comp does not update the comp. I will send you the AE file (assuming with no footage).
Thanks.
