3d Flag from still to animation
COW Forums : Zaxwerks
Sebastian Plamadeala
on May 7, 2011 at 9:02:59 am
Hello!
Is there any way to animate the transformation from a still image to the image with the 3dflag plugin applied?
I have a building projection and i want to make it transform from solid to a curtain like movement.
I tried matching the still and the 3dflag layer and then play with the opacity, but no luck. Masks also no luck.
Thank you,
Sebastian
Re: 3d Flag from still to animation
on May 9, 2011 at 12:37:55 pm
Anyone?....
Edward Wu
on May 9, 2011 at 4:32:12 pm
Hi Sebastian,
To create this effect, set the "Pre-Roll" setting to "0.0". This will let the flag start as a still image, and start animating like a curtain.
Best,
Edward
on May 10, 2011 at 8:29:28 am
Hello!
Thanks for the reply!
I did that, and for the return to a still frame i time-reversed the layer, and to add a little slow motion to the dropping of the flag because of the gravity, i played around with time-remapping.
I would really enjoy a start/stop animation parameter with animation possibility for the zaxwerks 3dflag version.... It takes a lot off making these kind of effects then displacement mapping.
Thank you,
Sebastian
Edward Wu
on May 10, 2011 at 5:37:03 pm
Hi Sebastian,
Thanks for the feedback. We'll consider these when releasing the next version of 3D Flag.
Best,
Edward
