Changing the axis point on an abject
COW Forums : Zaxwerks
Mike Schmitt
on Mar 22, 2011 at 2:56:32 pm
Hello there, again, I'm working on a client's logo, which is a star. The illustrator star is off-center in the modeling window, so I guess the star isn't symmetrical. When I make it spin on it's axis, the spin is extremely lopsided.
How do I change this axis point so that I can get an even spin?
Fernando Mol
Re: Changing the axis point on an abject
on Mar 22, 2011 at 3:29:49 pm
This tutorial may help you
http://library.creativecow.net/articles/hamad_serge/pa_pivot_point/video-tu...
I hope this helps
Edward Wu
on Mar 23, 2011 at 6:40:59 pm
Hi Mike,
To change the pivot point, select the object. Then, go into the Object Controls panel, and open the "Info" section. In the Pivot X,Y,Z fields, change the values to move the pivot point.
Best,
Edward
