All my materials are gone?
COW Forums : Zaxwerks
John Orban
on Feb 1, 2011 at 7:35:04 pm
Working on Mac 10.6.6
Opened up ProAnimator 4.5.1 for Mac today and found nothing in "Object Styles" - all bins are gray, empty - nothing in "Materials" as well.
I had a copy of the main Proanimator folder on my server, so I renamed the old file folder in "Applications" (I had a problem with PA crashing when trying to save a file, so I didn't want to lose the PA main file). Downloaded the PA Folder to Applications and started up the app in the new folder. Same thing - no materials - so there must be some file somewhere ELSE on the computer telling the app where all the files are?
When I look at the file structure of the PA folder (both the old and new are identical), I see the "Material Swatches" folder populated. I would have thought the .idx files might have gotten corrupted, but I don't think so, otherwise installing the new folder would have fixed that.
Not sure what to do at this point?
Thanks for any help.
John Orban
Re: All my materials are gone?
on Feb 1, 2011 at 7:45:18 pm
I've got a sinking feeling that PA4.5.1 is NOT compatible w/ 10.6.6???
Matt Rhodes
on Feb 2, 2011 at 2:16:55 am
Hi John.
PA 4.5.1 should be compatible with 10.6.6.
We keep a non-factory-default version of the swatches in your ~/Documents/Zaxwerks folder.
We use these swatches when starting ProAnimator. If the folder is empty, we won't show any swatches.
I suggest you find the folder named "ProAnimator" inside of "~/Documents/Zaxwerks."
This is where we keep the swatches.
Rename the "ProAnimator" folder to "ProAnimator - backup" and then restart ProAnimator.
Since the "ProAnimator" folder is missing, we'll copy the factory default swatches into a new "ProAnimator" folder.
You should then see the default swatches.
Note: In ProAnimator v5 (coming soon), we have put in a Reset button that will make this process much easier.
Let us know if you have any more questions.
Matt Rhodes
Zaxwerks, Inc.
John Orban
on Feb 2, 2011 at 3:20:04 pm
You da BOMB, Matt!
Thanks, everything is hunky dunky now!!!
John
