• | Can you import an audio track into Pro Animator
on Nov 23, 2010 at 6:55:06 pm |
What is the best way to time up camera moves to audio in Pro Animator?
Thanks in advance
Dave
• | Re: Can you import an audio track into Pro Animator on Nov 24, 2010 at 5:46:35 pm |
Hi Dave,
If you are working with After Effects, you can use ProAnimator as a plug-in and go into ProAnimator to time the animation to the audio. If you are working with ProAnimator as a standalone, you can open up the audio in a media player, and listen to the specific points where you want the animation to react and change the animation accordingly.
Hope this helps.
Best,
Edward
• | Re: Can you import an audio track into Pro Animator on Jan 10, 2011 at 2:23:41 am |
I created a scene in the standalone version - how can I get that scene into After Effects? I tried to import the Proanimator file and it crashed After Effects...
• | Re: Can you import an audio track into Pro Animator on Jan 10, 2011 at 5:38:54 pm |
Hi Michael,
First save your ProAnimator scene in the ProAnimator standalone. Then, in After Effects, create a Comp Sized Solid, and apply ProAnimator to the Solid. Then, in the Effect Controls Panel, click the "Click to Edit" button to open up the ProAnimator interface. Once you are in the ProAnimator interface, go to the File menu to load your ProAnimator scene.
Best,
Edward
