3D Flag question curtain raising up.
COW Forums : Zaxwerks
Justin Fitzpatrick
on Sep 22, 2010 at 9:53:27 am
Hi all,
Need bit of help, we have used 3d flag to drop a curtain, looks great, but it needs to then raise up slowly like in a theatre raising the curtain up, we cant seem to get the bottom to stay straight, the sides go up first then it bows in the middle.
Any ideas.
Justin
Edward Wu
Re: 3D Flag question curtain raising up.
on Sep 22, 2010 at 11:48:52 pm
Hi Justin,
After dropping the curtain, you may want to remove the wind speed so that the flag doesn't flag around on its own. You can also try adjusting the gravity setting and see if a higher gravity setting will help your curtain move more uniformly.
Best,
Edward
