3D Flag question about resolution
COW Forums : Zaxwerks
Justin Fitzpatrick
on Sep 22, 2010 at 3:48:20 am
Hi, we have just installed 3D flag for our latest project wich has a screen rosolution of 13000 x 1080. Its seems we can only set 10000 x 1080 but appears very small on the composition, much smaller than it should, and when we enlarge to fit the composition, we loose resolution clarity, not smooth and polygons.
Can the software work at our composition, why does it seem small in our composition when we set at maximum 10000 x 1080.
thanks
Edward Wu
Re: 3D Flag question about resolution
on Sep 22, 2010 at 11:47:00 pm
Hi Justin,
You may be running into a memory issue, which is why you're not seeing the flag at 13000 pixels while you can see it at 10000 pixels. When working with 3D Flag, do not enlarge the flag by means of scaling, or you will run into the issue of having pixelated edges. Try applying 3D Flag to a Comp Sized Solid, then change the dimensions of the Flag to fit your project needs
Best,
Edward.
