primitive plane as shadow catcher
COW Forums : Zaxwerks
Jim Wilcox
on Sep 16, 2010 at 9:46:59 pm
I am having an issue using a plane in Invig to catch the shadow of a sphere also generated in Invig. It catches just fine as standard color but as soon as I change it to shadow catcher, my shadow disappears.
Matt Rhodes
Re: primitive plane as shadow catcher
on Sep 17, 2010 at 5:16:35 am
Hi Jim.
Is your plane rotated by 90 degrees in the X axis?
Rotate it -90 degrees instead.
There's a limitation with planes where the rotation direction matters.
Let us know if you're still experiencing the problem.
Matt Rhodes
Zaxwerks, Inc.
Matt Rhodes
on Sep 17, 2010 at 5:25:23 am
Hi Jim.
Matt Rhodes
Zaxwerks, Inc.
Jim Wilcox
on Sep 17, 2010 at 3:15:19 pm
Matt,
That was it. Did I miss something in the docs on this? Just wondering what else I should be looking into?
Matt Rhodes
on Sep 17, 2010 at 3:57:26 pm
Hi Jim.
You didn't miss anything. This was a special case that never made it into the bug fix list.
It's something we should mention in the Shadow Catcher section.
Let us know if you have more questions.
m
