Flicker
COW Forums : Zaxwerks
Bill Triplett
Flicker
on Sep 1, 2010 at 9:30:31 pm
I have a Vista 64 system, 12 gig of memory,1 gig on the nvidia card and an I7 2.8 ghz processor.
My movie "flickers (?)" when rendered. What should I look at?
Edward Wu
Re: Flicker
on Sep 1, 2010 at 10:27:37 pm
Hi Bill,
If you are using Multiprocessing, this could cause your texture maps to be lost during the multiprocessing render. To fix this, import your texture maps into After Effects first, then apply them as a Layer Map. Then, apply the Layer Maps onto materials, and apply the materials onto your objects. After applying the Layer Maps, you should be able to render the movies out without the flickering.
Best,
Edward
Bill Triplett
Re: Flicker
on Sep 2, 2010 at 5:00:55 pm
Thank you. I've imported into AE, now I'm lost.
Bill Triplett
Re: Flicker
on Sep 2, 2010 at 5:38:08 pm
I have applied layer map 1 to one of the graphics but am unable to apply a different layer map to one of the other images.
Bill Triplett
Re: Flicker
on Sep 2, 2010 at 6:14:46 pm
Think I might have it working.
Bill Triplett
Re: Flicker
on Sep 2, 2010 at 6:42:12 pm
Turns out one of the layer maps is now fine but one of the others still flickers. They are both .tga images as layer maps.
Edward Wu
Re: Flicker
on Sep 2, 2010 at 7:38:43 pm
Hi Bill,
Try turning off Multiprocessing and doing the render again. With Multiprocessing disabled, you should be able to render without the the flickering.
Best,
Edward
Bill Triplett
Re: Flicker
on Sep 2, 2010 at 10:21:14 pm
Seems to have fixed the flicker but of course it takes longer to render.
