Illustrator and Invigorator
COW Forums : Zaxwerks
Bill Triplett
on Aug 31, 2010 at 6:19:18 pm
I have an image created in Illustrator CS 5. When I open it in Invigorator in only opens a part of the image. The part of the image that is not opening is "filled" with gradient mesh. Any idea what might be happening?
Edward Wu
Re: Illustrator and Invigorator
on Aug 31, 2010 at 8:12:27 pm
Hi Bill,
Gradient Mesh is not supported in 3D Invigorator Pro. This is why the gradient mesh is not showing up when you try to import it into 3D Invigorator Pro. If you convert the Gradient Mesh shape into a normal vector path, you should be able to import it into 3D Invigorator Pro without any issues.
Best,
Edward
Bill Triplett
on Aug 31, 2010 at 9:11:21 pm
Will do. Thank you.
