Combine Tracks
COW Forums : Zaxwerks
Stephen Smith
Combine Tracks
on Jul 22, 2010 at 2:42:05 pm
Is there a way to combine two tracks so they become one?
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
cowcowcowcowcow
Edward Wu
Re: Combine Tracks
on Jul 22, 2010 at 4:26:42 pm
Hi Stephen,
If you want to combine the objects from two Object Tracks together, select the objects from one Object Track. Next, go into the Track Commands menu, and select "Move Selected Objects to Track". Then select the Object Track you want to move into and your objects will be placed into the selected Object Track.
If you want to combine two animations together, you can go to one Object Track, and save the animation as a Object Animation preset. Then, go to the other Object Track, and under Object Animations, select "Append Preset".
Best,
Edward
Stephen Smith
Re: Combine Tracks
on Jul 22, 2010 at 6:35:04 pm
AWSOME! Thanks Edward, that did it.
Stephen Smith
