gradient artifacts problem...
COW Forums : Zaxwerks
jose luis martinat
on Jun 16, 2010 at 11:19:45 am
Hello,
Im working for with a project with proanimator via AE.My animation is pretty simple just a blue 3D square moving around. I get this pretty anoying circular lines on the faces of the square. It looks like i put a bad gradient color effect. It has like noticable lines going down it, like thick lines. You can see it in the picture I´m ataching
My composition settings are PAL/DV sqauere pixels. Pixel aspect ratio: square pixel. I would aprreciate any kind of help. I get this porblem all the time, even on the preview in AE and when I render it as an animation in hirh quality. Looks pretty bad when playing on projector.
best regards,
Jose Luis
Edward Wu
Re: gradient artifacts problem...
on Jun 17, 2010 at 12:23:17 am
Hi Jose,
I don't see your attachment. Please send the picture to me at ed@zaxwerks.com
Also, if you attach your After Effects project, I can take a look at your project setup.
Thanks.
Edward
