Invigorator Pro Shadows...........where?
COW Forums : Zaxwerks
Glenn Moore
on May 17, 2010 at 7:26:07 pm
Greetings all. Man, it's been forever since I've been in here.
I am trying to cast shadows in Invig Pro but I get nothing. I looked up the previous posts and I'm already doing what is suggested. I am doing the following:
1. Create 3D text
2. Create a Primitive Plane (floor or wall)
3. Turn on Cast Shadows and position the light
4. I hit Command (Mac) and press the TEST key to see my shadow effect and I get nothing.
5. I tried making the floor a Shadow Catcher and that didn't help either.
Am I missing a step somewhere?
MacPro, Invig Pro 4.08 (Just downloaded the newer one), 4GB RAM
Thanks in advance
Glenn
Edward Wu
Re: Invigorator Pro Shadows...........where?
on May 18, 2010 at 12:04:22 am
Hi Glenn,
The positioning of the object and the floor/wall is really important. This is usually what keeps users from seeing the shadows. You can try sending me the project file and I'll take a look at your setup to see what you're running into.
My e-mail address is ed@zaxwerks.com
Best,
Edward
Glenn Moore
on May 18, 2010 at 12:35:30 am
Thanks. I just figured out what I did. I switched from Invigorator Renderer thinking I'd get a better look. I switched it back and all is well. Thanks for taking a shot though.
Glenn
If you're gonna do it, try to do it well...if you can't do that then try to cover up your mistakes really well.
Edward Wu
on May 18, 2010 at 11:19:32 pm
No problem. Glad to hear that you were able to figure it out.
Thanks for the update.
Best,
Edward
