track 3d layer
COW Forums : Zaxwerks
Susan Cox
track 3d layer
on Mar 10, 2010 at 5:43:32 am
I have a globe that I want to spin, I created a solid and made it 3d and rotated the y axis. I then added a camera
In my invigator layer I chose the spinning solid and I'm using the comp camera.
The globe does not spin, am I missing a step?
Thnaks,
Susan
Serge Hamad
Re: track 3d layer
on Mar 10, 2010 at 5:21:18 pm
Hi Susan,
There are two thinks that come to my mind:
1- You still didn't apply a texture to your sphere. It's hard to see any changes when your globe has a simple plain color.
2- You didn't refresh your Invigorator layer after linking it to the 3D layer. You need to click the Draft/Best quality switch twice
(after each animation) to do so.
Does this help?
Salut.
Serge
NEW! InvigoMany-Media available here: http://www.nyc-visual.com
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
Susan Cox
Re: track 3d layer
on Mar 10, 2010 at 5:46:01 pm
Thanks Serge,
I actually did do both, but it's still not working, I'm not sure what the problem is.
cheers,
Susab
Serge Hamad
Re: track 3d layer
on Mar 10, 2010 at 6:06:19 pm
Feel free to send me your project (without media files)
(serge at nyc-visual dot com)
Salut.
Serge
Susan Cox
Re: track 3d layer
on Mar 10, 2010 at 7:21:51 pm
I would love it if you could look at this for me.
I'm using 3d invigorator pro 4.51 using ae cs 3.
Cheers,
Susan
Serge Hamad
Re: track 3d layer
on Mar 10, 2010 at 7:39:48 pm
Susan, Your globe was assigned to set # 5 and your tracking layer to Set # 1.
Just reassign your object in the Set-Up window to set # 1 and you are ready to go!
Best.
Serge
NEW! InvigoMany-Media is available here: http://www.nyc-visual.com
Susan Cox
Re: track 3d layer
on Mar 10, 2010 at 7:48:48 pm
How crazy,
I only have the object, and I assumed that it was set one, how do I know what set the object is assigned to.
and thank you, I thought I was losing my mind.
Susan
Serge Hamad
Re: track 3d layer
on Mar 10, 2010 at 7:56:18 pm
When you import or create an object, Invigorator automatically assigns it to set1. Unless you change the prefs in the User Prefs menu.
To know in what set your object resides, just select it in the Set-Up window and you will see a set # right to the object listing menu.
Salut ;-)
Serge
Edward Wu
Re: track 3d layer
on Mar 10, 2010 at 7:58:23 pm
Hi Susan,
By default, new objects that are created are placed into Set 1. However, you can assign objects to different Sets by going into Object Mode, and going into the "Set" drop down menu. The objects that you've selected will be assigned to the Set number that you selected in the drop down menu.
Best,
Edward
