Custom Edges Windows 7 and Vista
COW Forums : Zaxwerks
Thomas Haight
on Mar 3, 2010 at 2:26:26 am
I am using ProAnimator 4.5.1 with 64 Bit Windows 7 and Vista. I am having trouble getting my custom edges to load.
I know other posts have indicated that custom ede files should be saved to this location for Windows:
C:\Documents and Settings\ADMIN\My Documents\Zaxwerks\3D Invigorator PRO\Custom Edges
However, this directory seems to have special permissions set that prevent me from acessing it.
Has anyone else had this problem and found a way to work around it?
Edward Wu
Re: Custom Edges Windows 7 and Vista
on Mar 3, 2010 at 5:58:15 pm
Hi Thomas,
Since you're running into a permissions issue, try right clicking on the Folder, and going into the Properties menu. In the Properties menu, you should be able to change the permissions so that you can access the files.
Best,
Edward
