How to get a glass look
COW Forums : Zaxwerks
Mark Jackson
on Feb 26, 2010 at 4:08:32 pm
How do I make a material or object style look like glass?
Thanks in advance for your help.
Mark
Mark D. Jackson
Edward Wu
Re: How to get a glass look
on Feb 26, 2010 at 8:02:44 pm
Hi Mark,
To get a glass effect, use Object Style 15. To see the swatch names, go to the "Swatch" drop down menu on the upper right corner, and enable the option "Show Names & Notes". You can then apply Object Style 15 to your objects.
If you're looking to create your own glass material, the key is to make a material that has a high value set up for Highlight Sharpness and Brightness, as well as a high value set up for the Reflectivity. You will need to add a reflection map, then increase the transparency value.
Hope this helps.
Best,
Edward
