Casting shadows with AE Lights in Pro Invigorator
COW Forums : Zaxwerks
David Matthies
on Feb 13, 2010 at 6:04:58 pm
Can I use the AE lights to cast shadows on a scene that I have created in ProInvigorator? I don't need it to cast shadows on the AE layers, just on itself, but it doesn't seem to be working.
Edward Wu
Re: Casting shadows with AE Lights in Pro Invigorator
on Feb 15, 2010 at 5:56:09 pm
Hi John,
Sure, when working with After Effects lights, be sure to enable the "Use Comp Lights" setting for 3D Invigorator. In addition, go to the After Effects Lights settings, and enable the "Casts Shadows" option. Then, position the lights close to your 3D Invigorator objects, and you will be able to have 3D Invigorator objects cast shadows onto other objects.
Best,
Edward
