3D Invigorator Pro Chinese Fonts not showing
COW Forums : Zaxwerks
Alan Young
on Feb 9, 2010 at 4:44:04 am
I'm using 3D Invigorator in AE CS4 when I type in Chinese in the text box it appears ok, but once I press ok to go back to the 3D screen it turns into garbage.. Is there anyway to sort this out? Using Windows 7
Edward Wu
Re: 3D Invigorator Pro Chinese Fonts not showing
on Feb 9, 2010 at 9:12:36 pm
Hi Alan,
Unfortunately, Unicode characters are not supported as of now. So you will want to bring the text into Illustrator or Photoshop first, and then save the text as an Illustrator file. You can then use the "Open Illustrator File" command to import the text into 3D Invigorator.
If you need tips on how to import the vector art from Photoshop or Illustrator, be sure to check out our video tutorials which will cover the techniques.
http://www.zaxwerks.com/training/
Best,
Edward
