new version of 3d Flag 1.1.2 crashing in FCP & Motion
COW Forums : Zaxwerks
James Lee
on Jan 24, 2010 at 3:25:26 am
Can anyone enlighten me why my FCP & Motion are crashing as soon as I add the Flag 3d plugin
Edward Wu
Re: new version of 3d Flag 1.1.2 crashing in FCP & Motion
on Jan 25, 2010 at 8:42:41 pm
Hi James,
What version of Final Cut Pro and Motion are you running?
Also, try a clean install and see if this helps:
Go to your "Documents > Zaxwerks" folder. Then, delete the "3D Flag FX" folder.
Next, go to your "Root Directory > Library > Plug-ins > FxPlug" folder, and delete the "Zaxwerks3DFlag.fxplug" folder. Now, run the installer for 3D Flag and install the program. Set up your project in Motion or Final Cut Pro, and see if you are still running into the crash.
Let me know if this helps.
Best,
Edward
James Lee
on Feb 1, 2010 at 5:46:39 am
I'm running the latest version and did try what you suggested but alas no luck
Edward Wu
on Feb 1, 2010 at 5:58:59 pm
Hi James,
Please e-mail me at ed@zaxwerks.com
I have a beta version of 3D Flag FX that I can send over to you. This new version should be able to fix the issue that you are running into.
Best,
Edward
