3D Flag Zaxwerks edge limitations?
COW Forums : Zaxwerks
Jim Minton
on Jan 17, 2010 at 5:49:12 am
Anyone know how to make a Zaxwerks 3D Flag exceed the edges of the screen on all 4 sides? I keep getting a clipped image when I try to scale up. Is there another control to tweak? OUTER---WIDER?
Scratching my head...Thanks for your suggestions.
Edward Wu
Re: 3D Flag Zaxwerks edge limitations?
on Jan 19, 2010 at 7:14:22 pm
Hi Jim,
The way to do that is to first apply 3D Flag to a Comp-sized Solid, then adjust the size of the Flag from using the "Size From" setting. You can change the "Width" and the "Height" so that they exceed the screen size.''
Best,
Edward
Jim Minton
on Jan 20, 2010 at 12:50:57 am
Thank you. I will run a test asap.
