Help with model
COW Forums : Zaxwerks
Ernie Geefay
Help with model
on Jan 4, 2010 at 4:48:30 pm
I created this model in sketchup
Missile
It imports fine into invigorator pro for after effects
I can apply any of the standard materials to it.
But when I try to create a custom texture, like this
custom texture I can't get the texture to appear.
I've tried applying the same texture to other models that I've downloaded from various 3D model websites and the texture works fine
So I assume it is a problem with my sketchup model.
Can anyone help
Serge Hamad
Re: Help with model
on Jan 4, 2010 at 5:58:03 pm
Hi Ernie,
The link to your object doesn't work. Send me the project or object and I will be glad to have a look at it. (serge at nyc-visual dot com)
Salut.
Serge
New! InvigoMany-Media volume I & II available here:
http://www.nyc-visual.com
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
Ernie Geefay
Re: Help with model
on Jan 4, 2010 at 6:43:31 pm
Serge
That link should be working now.
Missile
I appreciate any suggestions you can give me
Ernie
Ernie
Serge Hamad
Re: Help with model
on Jan 5, 2010 at 12:46:38 am
Hi Ernie,
I believe the UV coordinates were not exported with your object.
I didn't have a 3D program on my laptop to introduce some. But as the object is very simple I created it for you using custom edges including mapping at the right aspect ratio for each part of the rocket.
I would advise you to check on the Custom Edge file to learn how you could do it yourself next time.
Looks like this:
http://www.nyc-visual.com/Ernie.jpg
Project:
http://www.nyc-visual.com/Ernie.zip
Salut.
Serge
Ernie Geefay
Re: Help with model
on Jan 5, 2010 at 7:34:54 pm
Thanks a lot!!!
I guess the free version of Sketchup doesn't export UV coordinates
I'll take a look at custom edges and see what I can design using Invigorator
Ernie
Serge Hamad
Re: Help with model
on Jan 5, 2010 at 9:50:21 pm
You are welcome!
If you are not familiar with custom edges, check out my tutorial on this. Just remember that in the newest versions of Invigorator you need to save your custom edges to another location rather then the one stated in the tutorial.
Salut.
Serge
