Invig Pro-custom edges not loading
COW Forums : Zaxwerks
Jim Wilcox
on Dec 22, 2009 at 11:58:10 pm
Running Inv Pro 4.5.1 in AE CS3. I cannot seem to get the custom edges to update. I have drawn new edges and saved them, even turned off all other edges in the custom edges document, but reloading does not change out any edges. Am I missing something basic?
Serge Hamad
Re: Invig Pro-custom edges not loading
on Dec 23, 2009 at 3:29:36 am
Hi Jim,
Where are you saving your Custom Edges? I think since a year or so you need to save them in a different folder then the older versions.
Here is the path for Windows:
C:\Documents and Settings\ADMIN\My Documents\Zaxwerks\3D Invigorator PRO\Custom Edges
Does this help?
Salut.
Serge
New! InvigoMany-Media volume I & II available here:
http://www.nyc-visual.com
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
Jim Wilcox
on Dec 23, 2009 at 5:05:21 pm
Serge,
Thanks for the info. I am on a mac, but I found where the custom edge doc is that is being read. Considering how you install the invig plug, how does that even get there?
Jim
Edward Wu
on Dec 23, 2009 at 5:11:15 pm
Hi Jim,
In the newer versions of our software, all swatches are copied into the Documents folder to let users have access to a set of "User Swatches" while the "Master Swatches" are preserved. This way, if you ever need to reset your swatches, just delete the Invigorator Pro folder in the Documents folder, and the swatches will be rebuilt from the Master swatches.
Best,
Edward
Jim Wilcox
on Dec 23, 2009 at 5:14:57 pm
Edward,
Thanks for the info!
Edward Wu
on Dec 23, 2009 at 5:29:24 pm
No problem Jim.
Happy Holidays!
