AE camera move to back side of ZW created Text
COW Forums : Zaxwerks
Joe Moya
on Dec 16, 2009 at 12:10:23 am
Why is it that when I do a 180 degree move to the back side of a Zaxwerks Pro-animator created 3d text... the results are words/letters that are not reversed? The text looks as if you are looking straight on. In real life, if you are looking from the back at the text... the text should be reversed... but, apparently not in in AE with Zaxwerks Why? Is there a way to make this look correct?
Edward Wu
Re: AE camera move to back side of ZW created Text
on Dec 16, 2009 at 6:23:35 pm
Hi Joe,
You should be able to see all sides of your ProAnimator 3D Text. If you are using the After Effects camera, be sure to enable the option to "Use Comp Camera". After setting up this option, you should be able to orbit around the object and see the back side of the object.
If you are still running into any issues, let me know.
Best,
Edward
