Rotation
COW Forums : Zaxwerks
Stephen Smith
Rotation
on Nov 21, 2009 at 12:24:13 am
I'm trying to rotate my illustrator text in Pro Animator FX for Motion. Both the "Rotate Around Common Center" and "Rotate Around Local Centers" in the Advanced Pose Positioning section rotate around the local centers which rotates each letter instead of all the letters. If I type the text in it works but if it is the Illustrator text is doesn't. Any way of grouping the illustrator letters inside of the Pro Animator FX?
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Serge Hamad
Re: Rotation
on Dec 2, 2009 at 5:13:13 am
Hi Stephen,
Did you try the hard grouping feature? It's located in the "Transition-Grouping" menu. (You need to select your transition first)
Salut.
Serge
New! InvigoMany-Media volume I & II available here:
http://www.nyc-visual.com
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
