Delete a Pose in ProAnimator
COW Forums : Zaxwerks
Joel Thiessen
on Oct 16, 2009 at 5:12:15 am
I've put an object pose in my timeline that I no longer want, only I'm out of undo's. How do I delete, remove, or erase object and/or lighting poses?
Edward Wu
Re: Delete a Pose in ProAnimator
on Oct 16, 2009 at 4:44:57 pm
Hi Joel,
If you are working within ProAnimator, you can select any pose you'd like to delete, and press the "Delete" button on your keyboard. If you are working within ProAnimator FX, you will have to hold the "Alt" button, then the "Delete" button. The command will then delete the pose.
In regards to the number of "Undos", you can go into the ProAnimator Preferences menu to increase the number of "Undos" from "5" to a higher number.
Best,
Edward
Stephen Smith
on Oct 29, 2010 at 3:59:50 pm
Edward,
This is great, you are such a life saver!
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
