Jigsaw Puzzle
COW Forums : Zaxwerks
John Rich
Jigsaw Puzzle
on Oct 6, 2009 at 1:34:06 am
I need some help with mapping. I've looked at Serge Hamad's excellent dvd several times and I still can't get this to work out.
I posted this earlier http://www.zaxwerks.com/forum/index.html
I created a a puzzle of four pieces in illustrator and separated them into four separate pieces and imported them into Invigorator Pro. Ok so far.
Then I imported a picture into a 720x480 PAR 1.2 widescreen comp and sized it to fit the comp window.
Then I pasted the paths from illustrator onto the picture and made four copies of the layer.
Then I deleted three different paths from each of the layers so I had outlines of each of the pieces.
I then precoomposed the layers.
Then using Serge's technique I used the precomp as a map and applied it to the front face of the piece in Invigorator.
Unfortunately, the map is too small. I 'm not sure how to enlarge the map to exactly fit the front part of the puzzle.
Any help would be greatly appreciated.
Thanks in advance.
John Rich
Serge Hamad
Re: Jigsaw Puzzle
on Oct 6, 2009 at 2:33:46 am
Hi John,
Basically, you should create different layer map compositions at the same aspect ratio then EACH puzzle piece.
Best you send me the ae project with the picture and ai file. I will be glad to trouble shoot it for you. (serge at nyc-visual dot com)
Salut.
Serge
Invigorator/Proanimator Training: http://library.creativecow.net/articles/hamad_serge/invig_training.php
John Rich
Re: Jigsaw Puzzle
on Oct 6, 2009 at 4:10:01 pm
Serge,
Thanks for looking at this. I sent you and email with the materials. Let me know if you need more info.
Thanks again,
John Rich
JOHNR
John Rich
Re: Jigsaw Puzzle
on Oct 7, 2009 at 1:41:40 am
Serge,
Thanks for showing me how to do the jigsaw project. I'll post the final result here. I didn't realize how powerful a piece of software Invigorator is especially combined with Illustrator.
Like everything else, it's all about learning to use it.
John Rich
JOHNR
Serge Hamad
Re: Jigsaw Puzzle
on Oct 9, 2009 at 3:59:29 am
John you are very welcome!
Salut,
Serge
