Using Hebrew Text
COW Forums : Zaxwerks
Zvi Twersky
Using Hebrew Text
on Sep 19, 2009 at 10:33:57 am
The closest I got to using Hebrew text with Zaxwerks Invigorator is to copy some typed Hebrew text from somewhere like Notepad, and paste it into Zaxwerks Invigorator. (Just typing Hebrew into Zaxwerks Invigorator gives me gibrish.) but when I apply Zaxwerks Invigorator and go back AE, the text is gibrish.
How can I use Zaxwerks Invigorator with Hebrew text?
(p.s. I don't want to rasterize it in Photoshop because then I can't edit the text)
Thank you
Edward Wu
Re: Using Hebrew Text
on Sep 21, 2009 at 4:57:31 pm
Hi Zvi,
The way you can work with Hebrew text is to use Adobe Illustrator (Photoshop can be used as an alternative). When you use the "Open Illustrator File" command, make sure to choose "Open By Layers" option. Then, when you want to edit the text, you can use the "Reload" command in 3D Invigorator to reload your Illustrator or Photoshop file. This way, you will be able to create your animation, and still reload the text if you have to make changes.
Hope this helps.
Best,
Edward
